Would it be possible for me to get faster than 512k?
I Have been stuck at 512k for more than 3 years now.
Here is my line stats from my D-Link DSL-G604T Router:
DSL Status
Connection Status Connected
Upstream Rate (Kbps) 288
Downstream Rate (Kbps) 576
US Margin 19
DS Margin 24
Modulation MMODE
LOS Errors 0
DS Line Attenuation 59
US Line Attenuation 63
Path Mode Fast Path
Would my line be good enough for 1MB if not 2MB?
At just under the 60db limit for 1mb you are pretty close - but it is under 60db downstream attenuation, so it should be possible.
If you raise a ticket and ask for a woosh test, you should get more accurate figues, then you can ask for a regrade on the basis of those if they come back ok.
Thanks very much, I'll try that.
