Worst ADSL specs ??
Worst ADSL specs ??
Hi All
just thought I'd share this ... we've just put our router on our ADSL line and can only just get ADSL - the line SNR is a massive 1.0 and loop is 56.5 - by my reckoning this shouldnt work Huh - all seems fine - good old Vigor routers!! Cheesy
Worst ADSL specs ??
Do you mean good old Draytek? Tongue
Hope it keeps working for you! Smiley
Worst ADSL specs ??
sorry, yes draytek - seems quite stable ... so far ...... @ 1mb!
Laser
Worst ADSL specs ??
Unfortunately the 1dB "just barely working" doesn't give much room for margin. Environmental conditions throughout the day and year can cause the SNR to wobble a bit...
56.5dB is a fairly high figure, but not so high that I'd expect you to see only 1dB SNR. The sum of the two is more often in the region of 60-80. It may pay to to do the usual stuff: check the filters, see what the stats are if plugged straight into the master socket with no other wiring connected, get latest router/modem firmware, minimise the ADSL signal run, etc etc...
