Why has my stable rate gone down after 5 weeks on max??????
Been on Max now for 5 weeks ish...Router has been syncing at 8128 since start without any disconnects and now stable rate has dropped to 7000...it was on 8000. what is the reason for this? oh well only 3 days left on contract
1 REPLY
If your modem/router syncs just once below your current MSR, then the MSR is dropped to the lowest speed you synced at.
Bad weather is one reason why the line may sync lower than usual, but if you connect at a higher speed consistantly enough after it drops, it should automagically go up again.
