Why does BT say throughput =3905 yet best i can get is 1500
petsyb
BT Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 5000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 5600 kbps(DOWN-STREAM) Actual IP throughput achieved during the test was - 3905 kbps
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
Fast A! However
/www.thinkbroadband.com/speedtest/r
Speed Test Results
Date 26/05/07 21:15:03
Speed Down 1423.35 Kbps ( 1.4 Mbps )
Speed Up 106.74 Kbps ( 0.1 Mbps )
Port 8095
Server speedtest1.adslguide.org.uk
PlusNet Speed Test
Your current speed is:
1.67 Mbps
modem connected at 5.6mb
petsyb
plus Net connection rate has me at
Your High-speed Broadband Service
Your current broadband speed is 5000 Kbps
My peak usage is 865.22MB
What is your PN account type? BBYW, PAYG, Premier, etc ...
3Mb FTTC
Plusnet Staff
Plusnet Staff
Fixes: 159
This sounds like it could be an rwin or mtu problem. Try following the guide on that page and see if you can push the speed up a bit higher.
 Chris Parr
 Plusnet Staff
