Why are my speeds so slow? ipprofile 250?
The results from brspeedtester site..
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 250 kbps
DSL connection rate: 448 kbps(UP-STREAM) 1280 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 199 kbps
Actual IP throughput achieved during the test was - 221 kbps
I can not download anything faster than 25ks i use to be able to download well over 160ks, what do i need to do?
I am plugged in at the bt master socket (in to the test socket behind the face plate) no other phones in use at all.
It takes 3 to 4 days of this before BT and PN systems notice your line has improved from whatever problem caused it to go below 500kb/s. Sad Been playing with phone wiring/extensions?
SW.
3Mb FTTC
Plusnet Staff
Plusnet Staff
Fixes: 159
Looks like this updated back to 2Mb this morning. You should just need to reboot your modem/router to see this come back.
 Chris Parr
 Plusnet Staff
I rebooted my router and ran the test again...
IP profile for your line is - 500 kbps
DSL connection rate: 448 kbps(UP-STREAM) 1056 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 388 kbps
Still not ideal. So if my router is showing 1056, i can still only download at 500 kbps?
Plusnet Staff
Plusnet Staff
Yep, in order for BT to set an IP profile of 1000kbps your line line needs to sync at 1152kbps or higher (for at least 3-5 days). At 1056kbps it will get a 500kbps IP profile.
See this page for details:
http://www.plus.net/support/broadband/products/faqs_and_guides/dslmax_guide.shtml
I'd suggest checking all of your wiring and filters, this is a good place to start:
http://usertools.plus.net/tutorials/id/13
any incorrect wiring and filters could easily cause this.
If it doesn't help can you post your line stats? This page shows how to get them on most routers/modems:
http://www.kitz.co.uk/adsl/frogstats.htm
Thanks for the reply.
I cant see how, in my case, wiring could be a problem, i have the microfilter plugged straight into the master test socket, with nothing else plugged in, Sky are not too happy about this and keep sending me letters saying they are going to disconnect me (multiroom), but if i leave it in, i have no internet connection, think i will have to call an engineer out.
Also the router i am using is a Belkin FSD7632-4 and as per this page..
http://www.kitz.co.uk/tute/belkin_commands.htm
None of the commands work, when i put
http://192.168.2.1/ADSL_status_main.stm
in the address bar, after logging in, all i get is
Can't open file ADSL_status_main.stm
Could this be a router problem? it is only a couple months old.
Just stuck my 3 year old filter on and the line jumped to 1696, done a speed test.
DSL connection rate: 448 kbps(UP-STREAM) 1696 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 365 kbps
Plusnet Leader
Plusnet Leader
Looks like a problem with the filter Cheesy
If you continue to sync with the exchange at the faster rate for 3 days then the IP profile will be increased accordingly - as will your throughput speeds.
