When can I expect to see an increase in speed?
Hi, I was maxed last Wednesday/Thursday. Since this time I have been rebooting my router almost every day.
The router is consistently synching at 8128/448 yet every speed test I've done seems to be stuck at 1.5 to 2 mbps download speeds. I've read that there can be a 3-day wait for the BRAS profile to be reset so presumably this should have happened by now?
Should I have expected to see an increase in speed by now and if this doesn't change within the 10 day period will I then be stuck with a speed equivalent to or worse to the one I had before upgrading?
Thanks, Martin
1 REPLY
snapper_mart
Don't hold your breath....my Speed has halved since the upgrade Sad used to connect religiously at 1.8Mbps on the old connection, since the upgrade I'm lucky to get over 1Mbps....currently running at around 300kbps .... Evil
