Whats up with relay.plus.net?
Can't seem to send mail via mail client or webmail..... Tried 2 different IP addresses (webmail) and can ping it from both but mail won't send.....
When using IE with Webmail it errors out saying "unable to connect to relay.plus.net, check settings."
JonathanW
What's the error that you get when using a mail client on your machine? The webmail issue is something that we're working on at the moment, and a Service Status has been posted regarding this.
Thunderbird asks to check smtp configuration. I can ping it......
JonathanW
I take it that nothing has been changed within Thunderbird?
What happens if you try to telnet to relay.plus.net on port 25? As this could be something that is being caused by a recent firewall/antivirus update.
Haven't tried telnet, and nothing has been changed in Thunderbird. Normally use Linux on my laptop which has no anti-virus.
If there were a way of configuring could you use the IP address of relay.plus.net rather than host name?
