Whats happening to my speed?????
Broadband Speed Test Results
Results from broadband speed test recorded on Tuesday, 23 May 2006, 13:45.
Your Connection
Speed Test Results
Downstream 474.3 Kbps ( = 0.5 Mbps )
Upstream 402.9 Kbps ( = 0.4 Mbps )
Should be 1mb. I am getting fed up with this.
1 REPLY
Are you Maxdsl? Actually looking at your post i can see that you are, you wouldn't be upload speeds like that if you wasn't.
Have you had the upgrade for more than 10 days? What's your synch speed?
Answer these questions and perhaps someone can help.
Lance.
