Whats best account wise
Evening.
I'm currently have a Premier Account but i suffer from some issues that i hope might be easily rectified.
I do shift work so when i most use the internet is always swapping times and i'm an avid 360 gamer.
At peak times and even off peak times i get poor connection that even effects other gamers when playing, especially in Gears of War.
Apparently the status of my exchange is RED due to high contention levels.
Will upgrading my account help my connection issues while gaming and speeds?
If so, what would be best to upgrade to, i want high speeds at all times (don't we all!) and mostly not o be hindered at peak times when gaming like i am at present.
Thanks for any help in advance.
1 REPLY
Plusnet Staff
Plusnet Staff
Fixes: 159
If your exchange is heavily contended then switching product isn't going to help this.
The new product set is out and very clearly defines the type of performance to expect on the different products.
Gaming is given a high priority across the network so you should be able to play them without problems.
 Chris Parr
 Plusnet Staff
