What the BT is going on
Walneyite
Since moving to MaxDSL I can set my watch by my connection drops... I loose internet connection at 19:45 each night, then again at 20:00 and twice more in the mornings at 5:45 and 6:00....
Is anyone else getting the same problem? It's not the weather as it has been sunny and dry for a few days then raining tonight and no matter what the conditions I'm getting 8.1mb connections each time with no change in up and down sync speeds
Could be the street lights Cheesy Seriously. The timing seems about right. Come on evening then turn off early morning.
Have you added anything to your line or made any kind of electrical changes in your home recently.
Or was it asoon as MaxDSL was enabled?
Also, are you interleaved?
I had exactly the same issue earlier in the year and it was the streetlights. BT engineer came out and fitted a new face plate with a built in micro filter and the problem went away.
