What's the best to be on now - ptn or pte?
benskia
Hi.
Just checking 'cos my speeds seem to have screwed a bit just recently.
Not quite as bad as a it was a few weeks back, but getting higher pings than usual.
Before, the server to be on was the ptn one.
Is that still the case?
Thanks.
Difficult to say, ptn-ag1 seems to have had some more serious problems recently, but the other telehouse north and east gateways haven't exactly been rosy. Apparently some of the problems have been isolated and resolved.
ptn-ag1 is a separate 155Mbs pipe that is not part of the main pool. PN put a select group of realms on it and it could not cope
If you are not one the the realms assigned exclusively to that pipe then you should never get assigned to it. The realms are I believe @plus.net and @plus.uk.net and possible a force9 one as well.
Ommin
Not true. Dave T says it's working fine. Wink
It's nice to be part of a select group ( not )
2Mb line
ptn-ag1
@plus.net
Metronet 155 pipe
I feel special.
Ommin
I feel special.
The thought that there might be a gateway worse than ptn-ag1 gives me nightmares. :lol:
Re: What's the best to be on now - ptn or pte?
The the best to be on now -is VALIUM Cheesy
i'm on ptn-ag2 and never seem to have any problems with it
Ommin
The main problems are with ptn-ag1 and they have been ongoing now for almost three weeks. Wish I could join you over on ptn-ag2 but I can't and yet I am constantly assured that I am not being disadvantaged by being in a 'select group.'
That is a completely separate gateway on one of the 622Mbs pipes. It is only ptn-ag1 that is linked to the problematic 155Mbs old metronet pipe
