What's happened with my SpeedTest
I thought things seemed a liitle slow and no wonder, look at this from the PN SpeedTest
18-09-2005 18:12:10 597.1
18-09-2005 18:09:25 571.2
18-09-2005 18:03:05 576.3
18-09-2005 17:52:49 504.9
18-09-2005 17:50:30 632.5
18-09-2005 17:49:26 777.9
18-09-2005 17:48:08 778
And this is on a 2mb Premier connection. All other speeds tests I've tried show similar results and my exchange doesn't appear to have problems. I have also rebooted/connected a couple of times.
So - what's gone wrong?Huh
Including the BT speed test?
No, not yet.
But even so, you'd think that 4 other tests I've tried can't all be wrong.
This isn't a uncommon occurence, but rarely as bad as this....ooops! I forgot - it's peaktime (I think).
I'll post further resuts later
The BT test will identify where the problem lies though.
Once identified you can then try to tackle the problem, be it Plus Nets or more likely, BT's problem.
subsailor
speed test
Had the same problem. Uninstalled latest ZA update, reinstalled previous Speed test OK.
To prove ZA at fault Ive done that exercise 3 times.
New ZA ,low speed. Old ZA, speed ok. I have no idea why. All I know it worked for me. I am running ZA 5.5.062.011
Finally got time to do a BT Speedtest at 21.47 and the result
1183 kilo bits per second (Kbps), your service bandwidth will have been quoted to you in kilo bits per second.
and my speeds using the PN Speedtester are
18-09-2005 21:51:19 729.4
18-09-2005 21:36:16 685.8
18-09-2005 21:02:56 379.1
18-09-2005 20:24:08 335.3
18-09-2005 20:01:42 712.4
So someting is clearly wrong somewhere and I noticed someone else has a thread about poor speeds tonight Sad
