What is going on???
What is going on???
Your current speed is:
489.20kbps
Which means you can download at 61.15 KB/sec. from our servers.
Is there a problem with speeds tonight? My 2Mb connection usually performs very well.
Example.......
Downstream 1946 Kbps (243.3 KB/sec) 2101 Kbps (inc. overheads)
Webpages are also starting and stopping before they fully load.
What is going on???
@woooshuk
hi i have slow speeds for the last 3 - 4 nights useing Usent 25 - 50k when i normally can get 200kb+ but after around about 00:00 they pick bac up to normal and are ok all through the day until the next evening, did a speed test from plusnet and 1790kb, but useing this forum like you at this time the web pages are slow loading ,
What is going on???
Hi woooshuk,
Have you checked your exchange status here
Sounds like you're exchange may be having probs.
Plusnet Staff
Plusnet Staff
What is going on???
Give the BT Speedtester a try
http://usertools.force9.net/tutorials/id/27
and see what speeds that is reporting. If that shows slow speeds too then it's likely exchange contention, especially if it's quick overnight.
What is going on???
I have similar problems, except my speeds seem to be poor most of the day, not just evenings. Dave I would be grateful if you could look at ticket 17471883, I've been waiting over 24hrs for a reply about this problem. My exchange changed to green from amber a few days ago.
6/9/05
00:35
301 kilo bits per second (Kbps), your service bandwidth will have been quoted to you in kilo bits per second.
09:20
Downstream 403 Kbps (50.4 KB/sec) 435 Kbps (inc. overheads)
Upstream 256 Kbps (32.0 KB/sec) 276 Kbps (inc. overheads)
09:25
278 kilo bits per second (Kbps), your service bandwidth will have been quoted to you in kilo bits per second.
15:00
Downstream 94 Kbps (11.8 KB/sec) 101 Kbps (inc. overheads)
Upstream 254 Kbps (31.8 KB/sec) 274 Kbps (inc. overheads)
15:05
53 kilo bits per second (Kbps), your service bandwidth will have been quoted to you in kilo bits per second
7/9/05
09:55
Downstream 297 Kbps (37.1 KB/sec) 320 Kbps (inc. overheads)
Upstream 251 Kbps (31.4 KB/sec) 271 Kbps (inc. overheads)
10:00
233 kilo bits per second (Kbps), your service bandwidth will have been quoted to you in kilo bits per second
Plusnet Staff
Plusnet Staff
What is going on???
I've passed the ticket on so the fault guys can run their remote testing for you.
What is going on???
Moderators note by John (johnessex) Quote removed as it was just a copy of the preceding post.
