What is going on.? At this rate, ill be down to bps soon
Things are going from bad to worse, as you can see....
I raised a ticket and was told BT find 400kbps acceptable for a 2mb line - well I certainly dont!!
15-06-2005 22:25:28 376.3
15-06-2005 22:20:06 334.4
15-06-2005 22:19:49 375.4
15-06-2005 22:19:33 366
15-06-2005 22:19:13 221.1
14-06-2005 18:29:32 764.9
14-06-2005 17:27:13 790.3
14-06-2005 17:26:46 983
14-06-2005 17:26:27 567.4
12-06-2005 13:04:10 1800.6
08-06-2005 22:11:14 1536.9
08-06-2005 22:09:01 978.9
08-06-2005 22:05:43 1523.1
08-06-2005 22:05:15 1450.4
08-06-2005 22:04:49 1329.7
08-06-2005 22:04:24 1599.7
08-06-2005 21:53:03 1038.9
08-06-2005 21:46:43 906.1
08-06-2005 21:46:28 788.1
08-06-2005 21:46:02 1124.7
Anyone else having probs....
I am on a clean install of XPSP2, so being told to check for spyware is not an acceptable reason for the above... If this keeps up, think I will be lookin elsewhere!
My speed is fine for 2mb:
http://www.adslguide.org.uk/tools/speedchart.asp?id=da9a25a410481eefbf362d0d129
Have you got Spybot Search & Destroy installed and Adaware Personal?
These are both free programes, I also have XP with SP2 but I still have these programes one and run them once a week. You can never have too much protection!
Give them a go and see what happens, you might be plesently suprised :shock:
Got them all done.... I work in IT support, so am pretty clued up when it comes to pc builds etc...
As I mentioned I am using a clean built machine, with little on it apart from the essentials... got all up and running, and connected to net, only to be astonished at my speeds!!
Daz, I don't have the link to hand but have you tried using BT's speedtester - it bypasses PN's network so will help point to which bit of the network is broken.
(Also try disconnecting and reconnecting - it could be a router issue)
Thanks....
Just got a new router, so decided to check that..... all seems to be ok after a config check, and reboot...
Its funny how things can work one minute, than not the next without any rational explanation - but then again, workin in support I should have known better!!!
Cheers
Not certain if this is the problem that you were seeing but when I read this post it reminded me of these issues with pth-ag2
Maybe explain why it resolved itself after the reboot?
