What card? please help
hi there,
i use a yorkshire bank Maestro card
i am currently tryin to update my details but when i try there is only 3 options whhich are AMEX , Mastercard and visa.
i was wondering if anybody knew which one i should select
thanks a lot
1 REPLY
I believe you have to phone up and get it put through manually, its rather stupid isn't it!
Running a quick search on the forums suggest that the easiest way to get this type of card added to your account is to phone up however it might only be accepted for one time payments and not monthly payments, assuming your card is tied with a current account why not set up a direct debit, which offers more security and saves you authorising it every month!
