Weird DNS/wireless Problem - Any Suggestions
Enviroment: Any one of a 3Com, Occam or D-Link ADSL modem and wireless router (tried them all).
PC clients running Win XP (Home and Pro editions)
Wireless (internal Centrino or PCMCIA cards or USB)
Symptoms: Client connected by wired LAN gets usable DNS address via DHCP i.e. can resolve URLs etc OK
Client connected by wireless doesn't get usable DNS address via DHCP. If client makes a VPN connection to its owners work VPN server and gets a usable DNS everything is OK.
Would prefer not to have to hard code DNS but understand the cause of the problem.
Any suggestions gratefully recieved.
Nic
Plusnet Staff
Plusnet Staff
When PC's connected via wireless what DNS servers does it get assigned?
If you do start->run type cmd and then enter ipconfig /all in the command prompt it should tell you what DNS servers have been assigned.
Cheers Dave,
This is the ipconfig with the wireless connection:
Windows IP Configuration
Host Name . . . . . . . . . . . . : M9ZZ4J2J-MSD
Primary Dns Suffix . . . . . . . : adm.ucl.ac.uk
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : adm.ucl.ac.uk
ucl.ac.uk
ac.uk
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Broadcom NetXtreme 57xx Gigabit Cont
roller
Physical Address. . . . . . . . . : 00-15-C5-54-5B-FB
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) PRO/Wireless 3945ABG Networ
k Connection
Physical Address. . . . . . . . . : 00-18-DE-70-77-33
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.2
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.1
128.40.203.9
Lease Obtained. . . . . . . . . . : 30 October 2006 21:30:43
Lease Expires . . . . . . . . . . : 11 November 2006 11:17:22
Ethernet adapter Local Area Connection 2:
Description . . . . . . . . . . . : Bluetooth Personal Area Network from
TOSHIBA
Physical Address. . . . . . . . . : 00-16-41-96-4E-16
I stuck the 128.40.203.9 one in as I know it's one at work (although there might be firewall issues etc......)
Plusnet Staff
Plusnet Staff
I'm trying to remember what having entries in the DNS Suffix Search List means.
ucl.ac.uk
ac.uk
I'd say it's unlikely to be the cause, but I just can't remember off the top of my head what that does.
128.40.203.9
I presume the router is set up to handle DNS and this hasn't been disabled. Can you set the DHCP settings in the router to pass on our DNS servers rather than using itself as the DNS server?
Dave,
I've just found another machine that does work OK. Its IPCONFIG is below. As far as I can see the only difference is the "node" value. I've no idea how to change this.
Host Name . . . . . . . . . . . . : BHSQZ0J-MSD
Node Type . . . . . . . . . . . . : Mixed
ucl.ac.uk
ac.uk
Description . . . . . . . . . . . : Broadcom 570x Gigabit Integrated Con troller
Physical Address. . . . . . . . . : 00-0D-56-7A-BB-79
Ethernet adapter Bluetooth Local Area Connection:
Description . . . . . . . . . . . : Bluetooth LAN Access Server Driver
Physical Address. . . . . . . . . : 00-10-C6-1B-1D-9D
Description . . . . . . . . . . . : Dell TrueMobile 1300 WLAN Mini-PCI C ard
Physical Address. . . . . . . . . : 00-90-4B-66-6A-01
IP Address. . . . . . . . . . . . : 192.168.1.7
128.40.203.9
Lease Obtained. . . . . . . . . . : 30 October 2006 21:50:00
Lease Expires . . . . . . . . . . : 11 November 2006 11:36:39
[Moderator's note by James - (sallyandjames): Duplicate post removed. Wink]
