Webstats
Webstats
Good morning support.
Nothing showing that I can see on the service status but I cannot get into webstats for my domains.
Nothing happens after selecting the domain from the webstats page.
Is there a problem?
Can't bring up the Emote Icons either? No response when clicking on them as well.
Regards
http://www.hmrg.co.uk
1 REPLY
RE: Webstats
> Is there a problem?
> Regards
> John
Ok call off the dogs.
Found the problem. it's caused by this over zealous "pop Up" killer that I installed a couple of days ago.
Removed this and everything works as normal now.
Damn software...grrrr.
Regards
