Webstats (how to covert Total KBytes into GB)
steed
When looking at the monthly webstats it gives "Total KBytes" for the month.
From what I have read you are given 250MB per day which equals 7.5GB per month (250MB time 30 days). So what would 7.5GB be in KB as listed in "Total KBytes" in the webstats?
I have looked for some information on the web and I have come up with the following:
1GB = 1000MB therefore 7.5GB = 7500MB
1MB = 1000KB therefore 7500MB = 7500000KB
So the maximum "Total KBytes" webstats figure for a month should not exceed 7500000
Can someone tell me if the figures and calculations I have used above are correct.
Yep looks alright to me - as an estimate Smiley
that can be used as a good estimate however there are 1024KB in a MB and 1024MB in a GB. there are also 1024bytes in a KB and 8 bits in a byte in case you're interested Smiley
Then there are 1024GB in a TB, 1024TB in a PB and 1024PB an an EB... Wink
Thomas
mmm terabyte....[the next one's petabyte? What's after that?]
It goes like this:
Byte
KiloByte - approx .one thousand bytes
MegaByte - approx. one million bytes
GigaByte - approx. one billion bytes
TeraByte - approx. one trillion bytes
PetaByte - approx. one quadrillion bytes
ExaByte - approx. one quintillion bytes
Hopefully some mad computer scientist might find that useful one day... Wink
Thomas
Plusnet Staff
Plusnet Staff
Then after that we have
zettabyte = 1180591620717411303424 bytes
and
yottabyte = 1208925819614629174706176 bytes
Hmm.... the Oxford English Dictionary only goes up to "exa-"... :?
Thomas
Edit: just realised something... zetta- and yotta- don't use the standard system of multiples of bytes, because they're not 2^x0, unlike the others I mentioned above.
You had me worried for a minuite then lol.
This definatly sounds like the realm of mad "computer scientists" or network engineers"
Chris
steed
Thanks for the replies Smiley
I have now recalculated using the exact figures:
July (250MB x 31 days) = 7.750GB
1GB = 1024MB therefore 7.75GB = 7936MB
1MB = 1024KB therefore 7936MB = 8126464KB
So the maximum "Total KBytes" webstats figure for the month of July should not exceed 8126464
Could someone explain what the "Hits by Response Code" are from the webstats. I know what Code 200 and 404 are, but what about the rest?
Code 200 OK -clicked on a link to a page that is there
Code 206 Partial Content
Code 301 Moved Permanently
Code 304 Not Modified
Code 401 Unauthorized
Code 404 Not Found -clicked on a link to a page that is not there
Ianwild
I found this page, which might help.
Regards,
steed
Thanks Smiley
[Moderators note (by Thomas): Quote removed, as it was unecessary, being a direct quote of the whole of the previous post.]
