Webstats, how long to generate?
Galaxy
I had a Domain added to my account a couple of weeks ago, and if I click on that address under webstats the new window opens with a 404 message.
Do I have to wait until next month before that changes?
Once you enable webstats then you should see the results within 24 hrs. Providing that there have been hits to your site.
Stats are normally run in the early morning so you usually get the previous days stats after about 0700 ish.
If you are seeing nothing after all this time you need to raise a link:Contact us ticket and have it checked.
Galaxy
Hmm, webstats were already active on the webspace before the domain was added, and the link is there to them.
I know i've had hits as people have emailed me/left messages in the guest book, my other domain's stats and username.plus.net stats are showing, but not the latest one.
I think the domain was added during the latest Webstat crash though, whether that affected it..... :?
grahambritten
Darren
Recently I have had problems with webstats on a second domain added to my enabled webstats. I was also getting a 404 when I clicked on the link.
I raised a ticket and it got fixed fairly quickly. Cheesy
Regards
Plusnet Staff
Plusnet Staff
I'd allow 24 hours for the webstats to be generated, if they aren't there after that then raise us a ticket and we'll sort it out. Although having said that there's a problem with them at the moment so have a look on service status for the update saying it's fixed first.
