Webspace
Webspace
I'm currently on ADSL Plus. This doesn't appear to let me use Frontpage/MySql/CGI etc on my 100mb webspace.
If I upgrade my account to Premier, will I be able to install things like phpBB and Mambo on my webspace?
I currently have some external space for hosting a site that uses Fantastico to install this stuff - I'm assuming this can't be done on plus?
Also, as my account is a residential account, would I be correct in assuming that the webspace can only be used for non-comercial purposes?
Cheers
Steve
LiamM
Webspace
Yep. Upgrading to Premier will give you 250Mb CGI / MySQL and webspace. Fine for phpbb and mambo etc......
Webspace
Thanks for that - what speed!
LiamM
Webspace
Upto 2Mb. What speed are you on now?
Webspace
I meant the speed of your response!!
I'm on 2mb Plus already, so it would be simple enough to goto 2mb Premier
Cheers
Steve
