Webspace - hits and bandwidth
Is there anyway to monitor the hits or bandwidth used on your web space? I would be curious as to how many visitors I have to my site.
Thanks for any help on this.
Ben_Brown
You should be able to do this by looking at the webstats for your space in the "Website Settings" part of the portal, here.
Thanks, but I found that previously and it only displays the percentage and amount of storage space used - there is no indication of page hits or bandwidth used. Am I missing something? TIA.
What account do you have. The advanced webstats are available for all residential accounts with the exception of BB+. If that is your account type, then that may explain the issue.
If not, have you activated the webstats from the website settings?
I have the £15 plus package so that explains it. Thanks for your help.
tahts BB+ and thus doesnt have webstats.
Sorry, there isnt any easy way of monitoring apart from maybe adding a hit counter to your site
No, its nothing major - just curious if it could be done or not.
