Webmail sending problems anyone this afternoon
Gel
Fixes: 10
Using webmail I can receive my +Net e mails {+from other ISP's}, but I cannot send even a very small webmail on +net portal.
Sending via Onetel portal it works fine, so problem must be with + Net.
After pressing SEND progress bar makes progress across, but then get white window & some text. 3 times in a row now.
Ben_Brown
Which Browser are you using?
Which protocol are you using (IMAP/POP3)?
Which mode are you using (Simple/Advanced)?
[edit]
I have just sent a test message successfully to 2 external email addresses using Opera 7, POP3 and Simple view.
[/edit]
Gel
Fixes: 10
