Webmail problems
Webmail problems
I am having problems trying to log into my webmail accounts from my brother's pc. I have checked all of the cookie settings and they are fine. I put my username+mailbox, then password. Webmail then attempts to action the pl file, fails to log out and then returns me to the login page again.
Any ideas anyone please?
Mark
Login Problems Ivan
Hi Mark,
I cannot tell you the precise cause of this problem but I've had similar problems with login process on the PlusNet portal and IMO I still think its a cookie related problem. Try giving CSC a phone if its an urgent problem otherwise send them a support ticket?
Ivan
F9 FOL Forum Moderator
F9 Broadband Premier 2MB User
Your Forum, Make Your Voice Count!
Webmail problems
Cheers Ivan.
I found the problem, although not sure why it happened. I noticed the box which offers advanced (IE6+) and basic (other browsers). My brother was using IE6 so really it should have worked, but changing to basic mode allowed me to log in.
Curious :roll:
Mark
Replying Ivan
Hi Mark,
Glad you found away around that one, Humm!! still as you so rightly say its abit curious!!
Ivan
Plusnet Staff
Plusnet Staff
Webmail problems
Hi Mark,
Has your brother got the pop up blocker enabled in IE? WIth advanced mode it opens webmail in a pop-up window. If that's blocked it will take you back to the login page.
Webmail problems
Hi Dave
No, no pop up blocker. I have it installed on mine though and when you log in to the mail account you are told to click on a link to open a new window. With my brother's you click to login, it goes through the process of attempting to login, fails and returns to the login screen.
It's not that much of a problem now though as i'm home, but I needed to access my mail desperately either Sat or Sun which I finally did.
Cheers
Mark
