Webmail and spam folder
Nick_Russell
With the spam filter on, messages are marked as [SPAM]. This is fine and I know I can set OE not to download these or delete then.
Is it possible to set up a redirect in webmail or elsewhere so that messages marked [SPAM] are automatically rediredted to the Spam folder in webmail? The folder options are greyed out in my webmail.
If I can do this, I don't have to download then onto my PC but I can periodically check via webmail just in case messages have been incorrectly marked as spam.
Fixes: 8
How does that help someone using POP3?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
This thread contains the answer to the question, although the folders in question are different, the same answer applies.
Jelv is correct that this doesn't help those using POP3
