Webmail: Timeout
Webmail: Timeout
I have noticed on the standard load and on the advanced login that the webmail times out and you have to log back in again. Its one of the problems with the older system I think.
It shouldn't ideally timeout until users log off or the connection is lost. It just makes it painful to continue using.
csogilvie
Webmail: Timeout
Do you mean you could be viewing a page then the login screen reappears? This has happened to me a couple of times (before the Email Problems IIRC) as well...
Webmail: Timeout
Yeah thats right, or you get the home page back and it just redirects and your webmail disappears! It can be a bit of a pain if you are in the middle of writing an email go away for a shortwhile, go to send the email, and then it requests a login again and you've lost the email! Its a bit of a pain if I'm honest.
