Webmail Feature Request: PDA interface
Is there any chance that you can give some thought to a very simple interface designed for accessing via a PDA?
ie minimum of graphics, text links in the left hand side of the page, optimised for a PDA screen etc?
[Moderator's note (by csogilvie): Topic modifed to fit with the requested title in the instructions]
1 REPLY
This has been suggest several times already. The idea will go into the pot with the rest of the ides/suggestions for consideration by PlusNet.
