Webcams
Webcams
Hi i get this message when trying to access the webcams.
Axis ActiveX Camera Control
The AXIS ActiveX Camera Control, which enables you to view live image streams in Microsoft Internet Explorer, could not be registered on your computer.
Why is this? :?
Webcams
Sounds as though you don't have active x installed or have an early version.
The cameras work fine for me with active x version 8
Webcams
Forget that last comment I'm getting confused with Direct x
Perhaps someone else can help here?
Webcams
This could be one of several things.
1: A corrupt/incompatiable registration library.
2: Your securty zone settings prevent the applet from registring.
Try reducing the level, quting all browsers (may be better to restart), and try aagin.
3: If you are on XP, you may be running under a limited account (wise for normal use). If so, restart the system, switch to administrator and try again.
Webcams
Well i just did an update on my Java Sun Microsystems that i download ages ago and now it works. Smiley
Aint much happening? :p
Ianwild
Webcams
Theres lot happening.
I will give you a wave. Smiley
Webcams
