Webcams
Fixes: 9
Webcams
I occaissionaly visit the plusnet CSC webcams to see how active things are, but over the last few days I get no output from the Customer Service Centre 2 camera.
I've reported it via the Wizard, but the response from the team is "It all works from my home machine Sir, can you try accessing it using a different browser"
Can some others test if they can see output from BOTH the Customer Service Centre cameras at Webcams
Maurice
Webcams
I also get nothing from CSC2 (labeled CSC3 on the screen). CSC1 works fine.
Fixes: 9
Webcams
Thanks Peter your output is just what I see. It was OK up untill a couple of days ago. The CSC obviously have a different route into the network though as they claim it is all working. See below! (standard test snipped!)
Support Wizard Journey] [Additional Information] Ask your Question here... The Customer Support Centre 2 Wecam accessed via http://portal.plus.net/webcams/ has not been working for the past several days. Is it planned to fix it? Maurice
CSC Agent 1 9:07pm, Wednesday 24th May 2006
Dear Mr Bickerstaff,
I have informed a member of our networks team regarding this.
Apologies for any inconvenience caused.
Regards,
xxxxxxxxxxx
CSC Agent 2
2:06am, Friday 26th May 2006
This should now be working as one of my colleagues has tested it from his home connection and viewed it successfully, can you please try again.
Regards,
xxxxxxxxxxx
Your comment 3:55pm, Friday 26th May 2006
I have re-tried and can confirm that it is still NOT working
CSC camera 1 is OK, CSC camera 2 is not OK neither is Application Development 3.
Maurice
CSC Agent 3 4:04pm, Friday 26th May 2006
After testing this from my home machine the cams all appear to be working, As such this could be an alternate issue.
Please advise if this works with an alternate browser.
Regards,
xxxxxxxxxx
To administer your account and for all your help and support requirements visit http://portal.plus.net/index_nlp.html
Your comment 5:36pm, Friday 26th May 2006
I do not currently have access to an alternative browser. I use IE6 and both cameras were working on my system up untill a few days ago!
I apologise for trying to be helpful and reporting the problem to you - I'll take the issue across to the Forums and see if anyone else is having problems.
Maurice
CSC Agent 4 5:39pm, Friday 26th May 2006
I'm sorry we are unable to shine any more light on the issue however my colleague has been unable to replicate the issue using his connection.
We can investigate this issue further if you could please test on an alternative browser.
Please advise once this has been tested.
Regards,
xxxxxxxxxxx
Fixes: 9
Webcams
Ive just tried the bigger pictures via Kitz's website - they give the same results.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Webcams
Unfortunately the CSC are mistaken on this one.
The cameras you are having trouble with have been borked for a while.
iirc this was raised to one of the Comms Team a while back but clearly hasnt been resolved yet.
Having said that, with everything else which is ongoing at present, i would imagine that its not high on the priorities right now.
Hopefully it will be sorted in the near future.
Webcams
Just to add to it, I cant see the cameras where the links are labelled CSC2 and Development 3.
It just stops with "If no image is displayed press Reload" or words to that effect.
Fixes: 9
Webcams
Well some success. After one more polite (?) interchange I've received this
This has been now raised as in internal issue under PID: 32581
It's no wonder the Question backlog is so large when even a simple problem report with no imperative deadline results in 4 exchanges of Ticket and trying to put the onus on my equipment! More training? Threats of Mand and a cricket bat?
Sad
Maurice
Webcams
Is it any wonder that the question backlog is so large when people are complaining about such trivial problems :?:
LiamM
Webcams
The webcam did come back recently - but it would appear to have died again.
Webcams
Ahh but what if when the looked into it, they realised that the problem was caused by something else that had been effecting many other people? Such as via one of the gateways that people are always complaining about?
Fixes: 9
Webcams
If you read the originating data - it was not complaining? I simply reported a problem on the website. No expectations of any rapid response, just a report. My major problem is in the way it was handled - turn it round so that it appears to be *MY* problem and the number of interchanges, and this forum entry to get it on to an action list. I still don't have any expectations of a rapid fix, I agree that there are many more important problems that need resolution. But at least it *IS* now on a list of things to be fixed at some point.
Now if this sort of response is the norm on *REAL* customer problems, and anecdotal evidence from the forums and usenet would suggest that it is, then fixing this single aspect of CSC activity by getting the first response correct could have a significant effect on the workload and on customer satisfaction.
I'm satisfied that this thread has now served it's purpose and can be locked if that is believed to be sensible.
M
Plusnet Staff
Plusnet Staff
Webcams
Two of the webcams are broken at the moment, it's been raised internally to get them looked at next week.
Fixes: 9
Webcams
I've just checked - and CSC 2 has been fixed. It is a bit mis-aligned at the mo - nice picture of the wall on the RHS.
It is good to see that even these trivial "problems" can be sorted if dealt with politely.
Maurice
