WebSync
WebSync
I was a bit disapointed having spent an hour trying to get this to work only to be told when i called Support that this was not working and currently with Developers. I was not given a timescale as to when it might be running. Even more disapointing that it still says that it is available or the website!!
Any ideas when it will be up and running?
[ Duplicate Post Removed - Josh ]
jberry
WebSync
I presume this is the webmail websynch feature. I am not sure whether this is an open problem and it is a bit too late to check now as development have gone home. I will take a look for you on Monday, please bump the post if you don't get a response - with the amount of taffic in here these days issues can quickly drop into obscutiry.
Regards,
Active Sync
Have not heard from Support/Developers about this! Any news?
Andrew
