Web, ping timeouts - connection problems
I appear to have connection problems this morning. Can't reach any websites and pinging my router from an external connection results in 50-75% packet loss.
Line was Maxed 4 weeks ago and no problems until today, sync speed is 7616/832 and I've tried rebooting a number of times over the past couple of hours
Can't see anything obvious in the router status
--------------------------- ATU-R Info (annex A) ----------------------------
Running Mode : G.DMT State : SHOWTIME
DS Actual Rate : 7616000 bps US Actual Rate : 832000 bps
DS maximum Rate : 10304000 bps US maximum Rate : 960000 bps
DS Path Mode : Interleave US Path Mode : Interleave
NE Current Attenuation : 19.5 dB Cur SNR Margin : 7.5 dB
DS actual PSDM(C) : 00000007 US actual PSDM(R) : 0000319d
ADSL Firmware Version : 41e2be2c
-------------------------------- ATU-C Info ---------------------------------
Far Current Attenuation : 21.5 dB Far SNR Margin : 4.0 dB
CO ITU Version[0] : 000f414c CO ITU Version[1] : 43420000
DSLAM CHIPSET VENDOR : < Alcatel >
INTL, DSTREAM bytes/depth= 64, symbols/codewords = 0, latency= 0*0.25ms.
, USTREAM bytes/depth= 8, symbols/codewords = 0, latency= 0*0.25ms.
CODE, DSTREAM fast parity bytes= 0, fast codeword= 0.
DSTREAM intl parity bytes= 16, intl codeword= 255.
CODE, USTREAM fast parity bytes= 0, fast codeword= 0.
USTREAM intl parity bytes= 16, intl codeword= 232.
Setting>>
FDQ : Enable, TCM : Enable, EC : Disable, Framing Mode : 3.
Running>>
FDQ : In Use, TCM : In Use, EC : Off.
DS : Framing Mode 3, US : Framing Mode 3.
ADI ADSL Firmware Version: 41e2be2c
Anyone any thoughts?
1 REPLY
Well back up and running as normal now after what feels like a million reboots!!!
Don't know what the problem was but comparing my router stats the difference would appear to be the Far SNR Margin figure.
Earlier: Far SNR Margin : 4.0 dB
Now: Far SNR Margin : 13.0 dB
What's "Far SNR Margin" and could the low value have caused the timeouts etc I was experiencing earlier?
