Web mail - like running through treacle.
Seems to me that webmail has been slow for some time now. What's the reason - has the shilling run out ?
Sending or receiving?
Just had a look at my default mailbox with webmail and it shows me my usual giant dollop of spam very quickly Cry
I've always found the PlusNet webmail very slow aswell. Other people seem to find theirs ok, but mine has always taken about 15 seconds to load an inbox (the inbox is empty).
Same here. Webmail's never been fast, but today it's so slow it's timed out several times.....
Webmail is like a dinosaur. I cant wait for the rewrite.
[Moderator note (acarr): Deleted duplicated reply]
Ianwild
Hi Guys,
As a quick test, do I have anyones permission to access webmail using your account login details?
I would like to compare speeds betwene the current webmail solution and the new one, which is in development.
Regards,
Ian
By all means use mine Ian.
And mine. I dont use it except to check for incoming.
Ianwild
Lol - I woulden't.
So which one you two has the slowest?
I reckon mine is Ok so you may be better off using one of the ones that say its slow. Or compare it with mine.
Mine is like the snail.
Ianwild
The beta webmail box has been taken off line for the rest of the day. I'm hoping they are going to bring it back on a public facing IP, so the beta testing might be able to start sooner than I indicated before. I will keep you updated!
Regards,
Ian
Ian
Maybe it is better that you use John's account. My main account is diverted to POP3 and my other account has accumulated mail in it.
Ianwild
Well, it will be the accumulated mail that is causing the slowdown. I want to see if the new server still suffers when there is a lot of waiting mail.
Regards,
Ian
This is mail I have dealt with and am hoping to move into folders on the new setup.
