WHY?
WHY?
I've been upgraded, I didn't complete the order when I saw the price, I backed out before the completion step.
So anyway I've just done a speedtest and my previous result as following with 1mb:
Date Speed Achieved (kbps)
07-12-2004 15:44:05 952.
Now that I'm on 2mb its gone down to:
726.7 kbps YOU
This is on the plusnet checker. Things were faster on 1mb! I only got 88kb/sec on a download from microsoft.com
Whats going on? :roll:
WHY?
Nodoby?
Also how do I raise a ticket?
Never done one before.
Cheers
WHY?
WHY?
Wont I need to contact plusnet though?
WHY?
Yes,
Either ring them on 0845 1400200 option 2 and ask them to refresh your connection or raise a ticket here http://portal.plus.net/support.html by selecting 'Contact Us'.
Plusnet Staff
Plusnet Staff
WHY?
If you click on Help at the top of the page and then Contact Us you can raise a ticket.
You say you didn't order a speed increase, is your router/modem now reporting that you are on 2Mbps? I'm wondering if the free speed increase has gone through.
If you are having a speed problem then make sure you try out the BT Speedtester, details can be found at
http://usertools.plus.net/tutorials/id/27
WHY?
I didn't order a speed increase, read that pdf and BT are making several visits to rochdale, so It's gone through.
Now if I contact you via email, can you refresh my connection within the next 10mins?
WHY?
PS the modem shows the line as 288/2272
