Voyager.home having problems?
Hey ...
i have the BT Voyager 205 router ... and when i go to voyager.home to open ports ... i can't seem to get to the advanced options.. because when i click on the advanced link .... the page doesn't change at all ...
i want to know if every1 is having this problem or just me ... and also will it be fixed soon ??
Can who has the same router check if teh site is working fine when u try to go to any of the links please
Ziggur
Hi Mitan
Check this link : http://corz.org/comms/hardware/router/router.troubleshooter.htm
and this :
http://corz.org/comms/hardware/router/205_admin_pages.zip
Corz has a fix that will get you into the Advanced pages.
I had the same problem until I added a byepass line in Proxomitron. If you are using Proxo then this is almost certainly what is blocking you.
Mike
i had the same problem. just disable your firewall and it should work. it took me a week to figure it out lol
ahh thats it Lol ... new firewall ...
thanks
I am having the same problem but none of the above fixes have worked for me. I have been to the corz site and followed their instructions as well.
I have installed ZoneAlarm (free) and Norton Internet security. Even when I disable them both, I still cannot access the advanced pages. I know the login is still admin/admin as I had to reset the box after it became unstable.
I thought it might have been something to do with the java virtual machine (I didn't have one!). So I installed the latest version from Sun (jre 1.5.0_05) but that has not fixed it either. Cry
Any more ideas?
Mark
Ziggur
Have you downloaded and used this file
it should get you into the Admin pages.
Mike
Mike
This may seem like a stupid question but dont I need a php server to execute this script on? I opened the file in notepad and there are also some special chars - so I wasnt sure waht to do with the file.
Do you have a link on the corz site that describes what to do with the file? Im looking for onw now.....
Mark
Ben_Brown
Yes, it is a php file so you would need to run it from a PHP enabled server. If you go here and scroll about half way down there are some drop-down options which you can use to navigate to pages on your router.
got it, thanks guys. FYI I was also able to upload the latest firmware (v1.Cool using a TFTP client (also on the corz site) - although this did not fix my menu problem. I will use the links on the corz site to make any further admin changes.
Mark
