Voyager 105 Booster?
I'm trying to find the booster setup file that was supposed to increase the speed of the USB ADSL Voyager 105 modem. Searched on the forums but all links found were either dead or no longer have the file on their servers. If anyone knows of a live link or can host the file it would be much appreciated.
AM
rja66
I have it. PM your email address & i'll send it.
prichardson
The Booster file in question is designed for the Voyager 100 and not the 105. The Voyager 105 supports upto 8Mb speeds by default and using incorrect drivers will likely cause you more problems in the long term.
You should be aware that whilst the Booster file is available from the BT site, is it provided as is and has no support with it.
