Virtual paths
Virtual paths
BT is reporting that some of the virtual paths at this exchange are not operating within BT Wholesale's planning guidance, although they are still operating within the product specification.
At busy times, your ADSL connection may operate at a reduced speed, although not all customers on your exchange may be affected. You should only contact support if there is no current ETA date set.
The ETA fix time is: 27 Apr 06
Record last updated: 10 Apr 06
IM getting this on my exchange but its past its due fix date is there any i should do or do i just live with it..
Also will this affect my maxdsl training period as i am on day 8 since upgrade
cheeers
