View My Usage
View My Usage
Anyone got any stats for Sunday ?
RE: View My Usage
I'm not aware of any current problems with the stats. If you are missing stats I'd advise raising a ticket on your account and we'll investigate. If anyone else is affected please do post to this thread also as it will help us determine whether there is a widescale problem.
Kind Regards,
Rob
| Robert Kelly.....................Unmetered & ADSL solutions
| Technical Support...................for Home & Business
| PlusNet Technologies Ltd...........@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
RE: View My Usage
> Hi,
> Kind Regards,
> Rob
I havent got any stats either.
RE: View My Usage
Thanks Douglas,
We will look into this. As a bit of an aside, looking at the upcoming developments from this side it appears that we are currently on target for the next phase of our Connect management system to be launched on the 1st May, although a lot is happening so this could get pushed back by a week.
This is will an overhaul of the system and functionaility which will remove the 2 day delay before stats appear.
With Regards,
Ian Wild
PlusNet Customer Support
RE: View My Usage
> Thanks Douglas,
> With Regards,
> Ian Wild
Thanks. Just to let you know that the Monday statistics for usage have appeared, but the Sunday ones remain absent. I dont use all my quota so it is not important.
Lynx: Poetry from Bath ... http://www.dgdclynx.plus.com/lynx.html
