Very slow speed
Very slow speed
This is supposed to be broadband. This has happened since I turned the router on and off earlier this evening. I found that I had a Plusnet firewall and have turned it off, but it's made no difference.
mikewogden
Very slow speed
Wow luxury...This is Broadband and its asynchronous. Pity its in the wrong direction...
Mike
Very slow speed
were all in a similar boat folks , I'm sure PN will speed things up again soon,once they were one of the best ISP's going. At least there is no memory chomping software with PN unlike AOL.
Problem is my friend d/l about 50GB a month at 700kbps+ on AOL and they dont seem to give a damn.
Fixes: 8
Very slow speed
@lauracrystalrose
Could you post the results you get from http://speedtester.bt.com/ please.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Very slow speed
Well not quite, but still seems seem to be large variations in speeds people are getting.
James
Very slow speed
And we need to run the BT Speedtester to see what sort of line profile BT have assigned.
mikewogden
Very slow speed
Dont seem to be able to run the speedtest.. It seems to stall everytime..
Mike
mikewogden
Very slow speed
At last I've got it to run
Results as follows:
Results Image not loaded
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 152 kbps
DSL connection rate: 448 kbps(UP-STREAM) 2784 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 113 kbps
If you wish to discuss these results please contact your ISP.
Comments from PN on these results would be appreciated.
Mike
Snarf
Very slow speed
Hmm well mine isn't that bad, but I'm on BB Premier and seeing the worst speeds I've ever seen with Plus Net tonight:
IP profile for your line is - 1000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 2080 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 913 kbps
My IP Profile dropped yesterday I believe for the first time since moving to MaxDSL. I'm still hoping this is all line related and not PN.
Azagoth
Very slow speed
Same here! My IP profile dropped from 7000, which it's been at since the beginning of MaxDSL, to 2500 today. It's infuriating as I know that my line can give me 6Mb downloads and I've got a 1.17Gb file to download later.
EDIT: I'm on the PAYG 2GB product.
mitchell20
Very slow speed
Same here now as well
Dropped from around 6Mb to below 1Mb now and I'm on PAYG:
Very slow speed
@mikewogden
BT's speed checker seems to die horribly when the network speeds have been throttled to an unusable level. I was getting exactly the same errors when my speeds were 37-250k for the whole month.
My speeds have improved since the 25th and currently fluctuate around the 700k mark at peak times (then suddenly flick back to 6MB at 12:20am every night.)
For comparison, my next door neighbours speeds are 3.5MB at peak times (F2S.) PlusNet finally (I think) recognize this as an error and are currently looking into it. However if you raise a ticket, you will get fobbed off with cut and paste replies - you really need to persevere - lack of ticket ownership is one of the worst problems with PlusNet IMO.
Eebuygum
Very slow speed
Absolutely dire speeds tonight, all confirmed by whichever speedtester you care to name. Pathetic.
Very slow speed
mine too, they were okay up until about an hour ago....
Last Result:
Download Speed: 1071 kbps (133.9 KB/sec transfer rate)
Upload Speed: 379 kbps (47.4 KB/sec transfer rate)
this takes the mick especially when I'm paying for PAYG...diabolical
Very slow speed
Last Result:
It's an upgrade - you can now use it for longer without paying any extra... :lol:
