Very poor speeds today
glloyd
Is anyone else getting terrible speeds this after noon? Mine are down to less to a third of what they should
Tracing route to portal.plus.net [212.159.8.137]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms my.router [192.168.0.1]
2 230 ms 225 ms 211 ms lo0-plusnet.ptn-ag1.plus.net [195.166.128.123]
3 221 ms 223 ms 208 ms ge0-0-0-103.ptn-gw1.plus.net [84.92.3.17]
4 226 ms 252 ms 251 ms ge0-0-0-22.pte-gw1.plus.net [212.159.4.9]
5 272 ms 273 ms 277 ms atm1-0.ptb-gw1.plus.net [212.159.1.89]
6 239 ms 232 ms 221 ms vlan18.pri.ptb-gw4.plus.net [195.166.129.130]
7 258 ms 236 ms 222 ms if2.ptb-al1.plus.net [195.166.129.39]
8 257 ms 253 ms 219 ms portal.plus.net [212.159.8.137]
Trace complete.
With the slow down occurring between the first and second hop, it might be worth trying a BT speed test which will help identify the source of the slow down.
Del
It does seem very sluggish today, the pages are taking a lot longer than usual to load and PlusNets own speedtest shows slower than usual ( also adslguide).
TBH. I'm not seeing any issues from my end. The portal is its normal sluggish self, but response times, for me, are fine.
Mine is terrible
Reply from 216.239.59.99: bytes=32 time=520ms TTL=245
Reply from 216.239.59.99: bytes=32 time=426ms TTL=247
Reply from 216.239.59.99: bytes=32 time=411ms TTL=247
Reply from 216.239.59.99: bytes=32 time=427ms TTL=247
Reply from 216.239.59.99: bytes=32 time=433ms TTL=247
Reply from 216.239.59.99: bytes=32 time=394ms TTL=245
Ping statistics for 216.239.59.99:
Packets: Sent = 6, Received = 6, Lost = 0 (0% loss)
Approximate round trip times in milli-seconds:
Minimum = 394ms, Maximum = 520ms, Average = 435ms
Would it be possible to post a tracert to see if there is any correlation with gateways?
Ben_Brown
Can you post a traceroute please?
glloyd
It's getting worse what ever it is.
2 271 ms 480 ms 272 ms lo0-plusnet.ptn-ag1.plus.net [195.166.128.123
3 263 ms 244 ms 250 ms ge0-0-0-103.ptn-gw1.plus.net [84.92.3.17]
4 226 ms 214 ms 200 ms ge0-0-0-22.pte-gw1.plus.net [212.159.4.9]
5 147 ms 156 ms 154 ms atm1-0.ptb-gw1.plus.net [212.159.1.89]
6 187 ms 211 ms 189 ms vlan18.pri.ptb-gw4.plus.net [195.166.129.130]
7 203 ms 209 ms 190 ms if2.ptb-al1.plus.net [195.166.129.39]
8 174 ms 164 ms 162 ms portal.plus.net [212.159.8.137]
Trace complete.
1 7 ms <1 ms <1 ms 192.168.0.1
2 447 ms 436 ms 408 ms lo0-plusnet.ptn-ag2.plus.net [195.166.128.53]
3 349 ms 348 ms 395 ms ge1-0-0-204.ptn-gw1.plus.net [84.92.3.105]
4 375 ms 389 ms 411 ms ge0-0-0-22.pte-gw1.plus.net [212.159.4.9]
5 391 ms 396 ms 409 ms atm1-0.ptb-gw1.plus.net [212.159.1.89]
6 360 ms 374 ms 370 ms vlan18.pri.ptb-gw4.plus.net [195.166.129.130]
7 397 ms 402 ms 417 ms if2.ptb-al1.plus.net [195.166.129.39]
8 414 ms 436 ms 402 ms portal.plus.net [212.159.8.137]
Trace complete.
I think the next step here is a BT speed test as linked above. That will either show that it is a Plus Net issue or a BT problem and certainly will go a long way in diagnosing this one.
I wonder if this is related (same very high first hop pings, but they returned to "normal" soon after)
glloyd
It's up and down like a yo yo.
2 45 ms 50 ms 47 ms lo0-plusnet.ptn-ag1.plus.net [195.166.128.123]
3 74 ms 71 ms 75 ms ge0-0-0-103.ptn-gw1.plus.net [84.92.3.17]
4 84 ms 84 ms 84 ms ge0-0-0-22.pte-gw1.plus.net [212.159.4.9]
5 112 ms 107 ms 76 ms atm1-0.ptb-gw1.plus.net [212.159.1.89]
6 86 ms 72 ms 74 ms vlan18.pri.ptb-gw4.plus.net [195.166.129.130]
7 78 ms 87 ms 98 ms if2.ptb-al1.plus.net [195.166.129.39]
8 95 ms 76 ms 70 ms portal.plus.net [212.159.8.137]
Trace complete.
2 141 ms 139 ms 149 ms lo0-plusnet.ptn-ag1.plus.net [195.166.128.123]
3 117 ms 174 ms 157 ms ge0-0-0-103.ptn-gw1.plus.net [84.92.3.17]
4 93 ms 87 ms 91 ms ge0-0-0-22.pte-gw1.plus.net [212.159.4.9]
5 113 ms 103 ms 102 ms atm1-0.ptb-gw1.plus.net [212.159.1.89]
6 71 ms 81 ms 75 ms vlan18.pri.ptb-gw4.plus.net [195.166.129.130]
7 71 ms 72 ms 79 ms if2.ptb-al1.plus.net [195.166.129.39]
8 88 ms 88 ms 92 ms portal.plus.net [212.159.8.137]
Trace complete.
ok whoops sorry crisis over, just did a router reboot to amuse myself:
2 19 ms 15 ms 15 ms lo0-plusnet.ptn-ag2.plus.net [195.166.128.53]
3 15 ms 15 ms 13 ms ge1-0-0-204.ptn-gw1.plus.net [84.92.3.105]
4 15 ms 15 ms 14 ms ge0-0-0-22.pte-gw1.plus.net [212.159.4.9]
5 19 ms 20 ms 21 ms atm1-0.ptb-gw1.plus.net [212.159.1.89]
6 21 ms 21 ms 19 ms vlan18.pri.ptb-gw4.plus.net [195.166.129.130]
7 20 ms 21 ms 21 ms if2.ptb-al1.plus.net [195.166.129.39]
8 19 ms 21 ms 20 ms portal.plus.net [212.159.8.137]
Trace complete.
ok whoops sorry crisis over, just did a router reboot to amuse myself.
That might simply mean you've connected to a different central/endpoint which is less congested (if that's the problem).
Tracing route to plus.net [212.159.8.137]
1 164 ms 167 ms 167 ms lo0-plusnet.pte-ag1.plus.net [195.166.128.64]
2 113 ms 119 ms 119 ms ge0-0-0-403.pte-gw2.plus.net [84.92.4.2]
3 175 ms 179 ms 167 ms ge0-0-0-22.pte-gw1.plus.net [212.159.4.9]
4 159 ms 167 ms 167 ms atm1-0.ptb-gw1.plus.net [212.159.1.89]
5 199 ms 179 ms 167 ms vlan18.pri.ptb-gw4.plus.net [195.166.129.130]
6 189 ms 191 ms 203 ms if2.ptb-al1.plus.net [195.166.129.39]
I got nothing to say :?
