Very eratic speeds tonight!!!!!!!!!!!!!!1
Well I'm on 2mb Premier and have noticed since around 4pm that my connection had been slow....... Just did a speed test and was gettin a dl speed of 262.3 kbps lmfao
Usualy its around the 1850 kbps area... Wots going on PNHuhHuhHuhHuhHuhHuhHuhHuhHuhHuhHuhHuhHuhHuhHuhHuhHuhHuhHuh
Fixes: 8
Not affecting me currently (?). I'm on 2 Meg Premier.
Even the portal seems to have speeded up today? Perhaps the power outage has cleared a few 'drains'
Maurice
Fixes: 8
antrobus6: What result are you getting from a BT speedtest?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Between 250 and 800......Just about to check now.I'll report back
Its funny isn't it,You start moaning on here and things go back to normal...Just did a test and the results were 1863.7 kbps
:shock:
