Very Ssssssssslow Internet connection
Here are my ping stats for 2 sites this evening.
Pinging www.mmch.co.uk [212.227.118.81] with 32 bytes of data:
Reply from 212.227.118.81: bytes=32 time=2087ms TTL=240
Reply from 212.227.118.81: bytes=32 time=2266ms TTL=240
Ping statistics for 212.227.118.81:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 2087ms, Maximum = 2266ms, Average = 2221ms
Pinging www.overclockers.co.uk [212.47.87.75] with 32 bytes of data:
Reply from 212.47.87.75: bytes=32 time=2279ms TTL=241
Reply from 212.47.87.75: bytes=32 time=2266ms TTL=241
Reply from 212.47.87.75: bytes=32 time=2265ms TTL=241
Reply from 212.47.87.75: bytes=32 time=2280ms TTL=241
Ping statistics for 212.47.87.75:
Minimum = 2265ms, Maximum = 2280ms, Average = 2272ms
As you can see these are unacceptable, whats the problem. I am connecting with ISDN, tryed diconnecting and reconnecting with no difference.
colinjh
RE: Very Ssssssssslow Internet connection
I will second that.
Pages are so slow, sometimes refusing to load, started Sunday evening
Apologies for the delay, I had started looking into this for you.
At what time did you experience the slowdown?
Can you just ping 212.159.4.4, then tracert to the same address and post your results back?
This will allow me to investigate further.
Kind Regards
Duncan
| Duncan Scotland          Unmetered & ADSL solutions
| Senior Technical Consultant   for Home & Business
| PlusNet Technologies Ltd. @ http://www.plus.net
+ ------- My Referrals - It pays to recommend PlusNet ---------
Pinging 212.159.4.4 with 32 bytes of data:
Reply from 212.159.4.4: bytes=32 time=63ms TTL=252
Reply from 212.159.4.4: bytes=32 time=62ms TTL=252
Reply from 212.159.4.4: bytes=32 time=74ms TTL=252
Ping statistics for 212.159.4.4:
Minimum = 62ms, Maximum = 74ms, Average = 65ms
Tracing route to 212.159.4.4 over a maximum of 30 hops
1 1 ms 1 ms 1 ms 192.168.0.1
2 68 ms 72 ms 66 ms nac0431987-plusnet-c1-hg3.mdip.bt.net [194.74.71
.174]
3 73 ms 65 ms 71 ms 192.168.254.3
4 68 ms 77 ms 77 ms 192.168.253.2
5 76 ms 71 ms 66 ms 212.159.4.4
Trace complete.
Just completed tracert, pings now higher but page loads on certain sites ultra slow, only started happening this afternoon.
Connecting via isdn. Modem shows speed at 64k but pages dreadfully slow and it took forever to get past the veryfing password stage to connect at the beginning. Only noticed this in the last hour.
Mark.
Regards,
Mark Henderson.
(thetop)
www.sussexbridalcars.co.uk
Still slow this morning, cannot access certain sites. must be something wromg at your end, I can access the sites OK through BT 0845 dialup.
Connected 1st time but still very slow for me too, took 2mins and 37secs to open forum page.
Mark.
Regards,
Mark Henderson.
(thetop)
Hi Mark,
Will look into this further, you should not be having any speed issues. If you are still finding it slow, try a ping on an external site and then on an external site through our 0845 number. Are you experiencing the same issue on both numbers?
| Kevin Revill ............... Unmetered & ADSL solutions
| Customer Support .................. for Home & Business
| PlusNet Technologies Ltd. ....... @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
Going on with this thread, i noticed sometimes the net is slow.
Account adean01
here is a trace rt
No 4 n 6 look to be a problem
Tracing route to www.uk.lycos.de [213.193.18.47]
over a maximum of 30 hops:
1 <10 ms <10 ms <10 ms RAINBOW-TYA4H1X [192.168.0.1]
2 70 ms 90 ms 71 ms nac0431987-plusnet-c1-hg3.mdip.bt.net [194.74.71
.174]
3 70 ms 80 ms 80 ms 192.168.254.3
4 721 ms 1402 ms 290 ms 192.168.253.2
5 100 ms 80 ms 80 ms 212.159.4.4
6 801 ms 281 ms 80 ms 241.core01.access.plus.net.uk [212.159.15.241]
7 80 ms 90 ms 90 ms dolpiaza-atm.core.telehouse.plus.net [212.159.1.
66]
8 80 ms 90 ms 90 ms 213.166.3.149
9 1142 ms 1152 ms 561 ms 213.232.64.50
10 80 ms 90 ms 90 ms p6-2.london2-cr4.bbnplanet.net [212.133.14.89]
11 80 ms 90 ms 90 ms p1-0.london2-cr3.bbnplanet.net [195.16.175.173]
12 100 ms 90 ms 90 ms p5-0.londen3-cr4.bbnplanet.net [212.133.14.34]
13 90 ms 90 ms 100 ms r12-Fe4-0-0.Ldn-KQ4.UK.KPNQwest.net [195.66.225.
90]
14 90 ms 80 ms 90 ms r6-PO3-0-0.ldn-KQ2.UK.kpnqwest.net [134.222.229.
217]
15 90 ms 90 ms 90 ms r4-PO1-2.ledn-KQ1.NL.kpnqwest.net [134.222.228.2
45]
16 80 ms 100 ms 90 ms r3-PO6-0.ledn-KQ1.NL.kpnqwest.net [134.222.229.1
22]
17 100 ms 100 ms 101 ms r1-Se0-1-0.ledn-KQ1.NL.KPNQwest.net [134.222.230
.5]
18 90 ms 100 ms 101 ms r1-Se0-1-0.0.ffm-KQ1.DE.kpnqwest.net [134.222.23
0.14]
19 90 ms 100 ms 101 ms r2-Se0-0-0.0.ffm-KQ1.DE.kpnqwest.net [134.222.23
0.106]
20 110 ms 120 ms 111 ms 134.222.105.214
21 110 ms 110 ms 120 ms 213.193.26.252
22 110 ms 120 ms 131 ms www.uk.lycos.de [213.193.18.47]
Trace complete.
as to confirm from phone conversation
192.168.253.2
is not one of my internal computers.
Last Node in my network onto yours is at the rainbow server.
Hope that helps.
Regards
Gary
I agree that everything seems very slow at the moment. Pings when playing MOH are in the region of 400+ (unplayable). What I will say though, is that the BT Openworld FRIACO based system is just as bad. I tested this evening using works dial-in, and got the same high pings.
Hope we get something soon - missing my Medal of Honour :-(
Seams a bit faster now, but i had to use UK2 0845 dial up cus i was fed up of waiting.
newinvention
Weds. 20th: Internet connection via Friaco definitely very slow today - particularly on Plusnet portal and accessing my website hosted by Plusnet. Be glad of some explanation. I'm having to connect using my freenetname dialup a/c.
