Ventrilo again
Ventrilo again
Have you lot taken ventrilo off priority again as Im getting pings of 1000-4000 for the last two days. Unacceptable Im afraid whats going on? This is the very last time I put up with this nonsense. BT is beconing and Im near to cancelling Plus now.
Answer please support Jonny's.
willhome
Ventrilo again
i wounder if its the same as teamspeak problem with all getting. Is your ventrilo ona default port. or different. if its different, see if you can rest it on a default port serveR?
Plusnet Staff
Plusnet Staff
Ventrilo again
I'm not aware of any problems are any changes that have been made, what port are you using? I can check to see if it's listed in the Ellacoya database against Ventrilo.
