VPn Connectivity - Falls of a cliff at 4pm?
I work from home and have reasonable connectivity through my firms vpn all day, but at 4pm it becomes unusable and ends up being so slow that the mail client cant even find the servers and crashes.
I am running the £21.99 package and am using an 8mb connection with a Netgear wireless router
I got reasonable speed (is it - iam no expert?)using the speed test without the VPN http://www.speedtest.net/result/82589126.png
I am usin vsgate 5.1
VSGate 5.1 Host emalonvsg204 (10.250.142.123)
IDLE TIMEOUT: 1 hrs 0 mins 0 secs
SUSPEND TIMEOUT: Disabled
KEY UPDATE PERIOD: 0 hrs 15 mins 0 secs
PUBLIC KEY: DIFFIE-HELLMAN
KEY EXCHANGE: PERFECT (Symmetric + Asymmetric)
ENCRYPTION: TRIPLE DES (3 KEY)
ENCRYPT LEN: 168 bits
PUBLIC LEN: 512 bits
ACCESS LIST: DEFAULT
LOCAL PORT: 21 will map to 5500 to 5999 (ftp)
80 will map to 7500 to 7999 (?)
Whys does my VPN die at 4pm ?
James
Hiya,
Not something I know enough about to really help you out, other than to suggest that you raise a ticket, which we can then pass through to our Networks Department.
Re: VPn Connectivity - Falls of a cliff at 4pm?
In a word: ellacoya. Blatantly your VPN isn't being classified as gold; and if it is being classified as gold, then the ellacoya is obviously dropping enough packets to slow it right down and make it unstable.
Other people are reporting difficulties with VPN and other encrypted traffic on Ellacoya-enabled (or do I mean disabled?) ISPs.
http://forum.utorrent.com/viewtopic.php?pid=227489
Fixes: 8
I had a VPN connection open today from around 11am until about 8pm when it had the first drop of the day. Speed was normal throughout.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
