VPN Problems
VPN Problems
The VPN setup that I use for dialing into my work network doesn't work...
I think I've narrowed it down to the fact that the VPN Client uses a non-500 IKE Port.... and in fact uses port 4500 on UDP as the IKE port...
Is there any reason as to why this port is blockedHuh
1 REPLY
VPN Problems
The ports that PN block on each of the products is detailed here: home and business.
4500 is not one of them so I think you need to look elsewhere for the problem in your case.
VPN can be used on all PN products.
