VNC Becoming Unusable
Pathfinder
After 8AM it grinds to a halt or times out.
Thats it, carry on.
Re: VNC Becoming Unusable
Are you using it on the default port? Is so, try changing.
James
Which port are you using it on?
Pathfinder
5999
Sorry, typo. That should be "off" the default port not "on" it! That makes quite a lot of difference in context! Shockedops:
If you're running on the default port, it should be OK. If you've changed port you can expect problems because that kind of trickery is more than Plusnet can handle ATM.
James
I'll check with Carl and see if he can suggest anything else to try.
James
Try using:
5800 - 5810
5900 - 5910
6000 - 6063
