VMBU - so high usage
andy020
My usage has increased but ido the exact same things i did on the old.
With the old VMBU i got 7 - 8 gig a month this new one i hit double that nearly hitting the limit i don't think this new VMBU is fair.
Can someone advise me on what to do please i don't want to change product and if i did hit the limit and go over most months what would happen to me?
Hi there.
I wonder if your usage has actually doubled or have you fallen victim to the last entry in this Service Status Announcement.
http://portal.plus.net/central/forums/viewtopic.php?t=43664
If you raise a query via help and support, hopefully someone could confirm that for you.
andy020
Thanks for this information i have sent a query lets see what the answer is Smiley ill post here when they answer and thank you if they fix it Smiley it's great that you brought this to my attention
I have found the same. My usage appears to have increased since the new VMBU.
I have used just over 3gb this month compared to 1.5 in April and 1.94 in March. I changed to PAYG in May and since then my usage appears to have doubled!! II personally think the usage monitor is not accurate.
