VMBU problem, maybe a rep could explain
The VMBU seems to have a problem
Looking at my usage it's saying:
Peak-time usage so far this month:
20.33GB
Usage so far this month:
0.04GB
Help how can this be so?Huh
Midville
Maybe the peak usage hasnt reset itself for the new month, have you just go into your new biling period? Was that your last months usage out of interest?
My new month does start on the 18th but my usage for the month stood at 69.2GB
If it's resetting then should'nt all the usage be reset??
All the usage should be reset from midnight tonight if its the end of the month reset?
Midville
Was just wondering if 20.33Gb was last months peak usage. I think there has been another who's peak usage didnt reset, PNs devolopers are looking into it.
Plusnet Staff
Plusnet Staff
Looks like Ben raised this to the developers a little earlier today, take a look at the following thread.
So will this be sorted out as I don't want that email and my account throttled
Why has my usage been reset before the end of my billing monthHuh
Any news on this as the thread you pointed to was picked up by BBrown at 09:00am this morning?Huh
Plusnet Staff
Plusnet Staff
Yep, it will sorted, the developers are working on it now. This error wouldn't trigger an email as the usage data is taken direct from the raw data rather than VMU.
I don't know the whys yet, but will check up when the developers have fixed it.
Thanks for that, but why has my usage been reset before the end of my month??
My month starts on the 18th so my usage should be reset from midnight should'nt it?Huh
Plusnet Staff
Plusnet Staff
As I said, I personally don't know why it's happened, but the developers will and I'll get the answer from them when I can.
I raised ticket 18006854 about VMBU on 09/11/05. It was last updated by a CS rep on 11/11/05 with no suggestion that there could be a fault. I come on here today and find out that there's a known problem with VMBU!
Why hasn't my ticket been updated? What have CS been doing since 11/11/05 to resolve the ticket?
If I hadn't come on here I wouldn't have know anything about it.
I Just had a look at my VMBU and its WRONG it was re set today and according to the meter i have used 20.77GIG.
Plusnet do i have to open a ticket?
I suggest others keep a close eye on VMBU
edit:
Ticket: 18086661
DU Meter Daily Report
Period (Date) Download Upload Both Directions Dial-Up
17/11/2005 180,769 KB 200,880 KB 381,649 KB 0 sec
18/11/2005 476,225 KB 521,334 KB 997,559 KB 0 sec
All sorted.
Tnx plusnet Wink
ChrisR
Is it only premier customers who have a peak time usage meter?
Chris,
The 30/100 Gb measurements only apply to premier (and similar) accounts, BB+ users arn't affected by them, so they don't see them.
well the VMU shows me as using 3.21GB between midnight and 0700 this morning, yeah i should be so lucky on premier :shock: still only 2 days left before i migrate hopefully...
