VMBU - Strange???
VMBU - Strange???
I have just had a quick look at my VMU and have noticed it is showing 4MB peak time usage today. I thought it was 2 hours behind and therefore we aren't in to peak time yet, surely it should be zero :?
VMBU - Strange???
no, it can be "up" to 2 hrs behind
tends to be a max of 30mins in reality though
so that is correct
VMBU - Strange???
Ah, the famous "up to". That explains things then, I do have a torrent uploading at a max 15KB\s so there will be activity. Cheers. Please close or delete the thread if you like Cheesy
VMBU - Strange???
Indeed, I think they just say 2 hours to make sure you're aware it can be that far behind, maybe clarifacation is needed with the new peak time stuff?
chymorva
VMBU - Strange???
I had a discussion (see here) back in March about the wording at the bottom of the page. It is still wrong !!
