VMBU / Peak time management problem
My account (BB+) is on level 1 management, as shown here:
Yet, if i view the amount used this month, it's under 1GB, as shown here:
Is this down to my bandwidth usage not been reset or?
Ticket: 19288928
michaelscott
It's May 1st today, so likely any usage "this month" is what you've used today.,
My billing day is the 26th, so my month runs from the 25th to the 25th, as shown at the top of the second image.
It does look as if either it hasn't been reset properly (which should be all automagic and smooth with the new system, hehe) or its not separating your peak and off-peak.
tcs2000
It's just a complete mess and it's about time Plusnet sorted out the VMBU.
They've had a month to do it so what's the big problem PlusnetHuh?Huh
Update
I have added your details to internal Problem (ID 31943). Any updates to this will be reflected in work carried out on your account. You may request updates to this problem here.
Regards
Well that's a step in the right direction Smiley
Have you had the management removed though? this shouldn't be a complex process and should be priority for those impacted by the problem. Or have been offered a refund for the time when the connection you are paying for is not useable in the way it should? If not I'd push for it, this is far from the first time these problems have occurred.
I have a similar problem today on my Payg 10Gb account. Just raised a ticket, number is 19299702.
All web access is now blocked, I can see portal.plus.net OK, but anything else brings up a message:
Access control configuration prevents your request from being allowed at this time. Please contact your service provider if you feel this is incorrect.
Help please. Cry
SW.
3Mb FTTC
This is annoying, i've now recieved my MaxDSL upgrade but can't tell if it's performing well due to it being wrongly 'managed'
Tell me if I'm being stupid, buy why can't Plusnet turn off the restrictions now, while sorting out the underlying fault(s)? Also, it would be nice if we have some feedback on these investigations. The only correspondence I get are emails saying I'm on the next level of restriction....
Help please. Cry
SW.
suffereing the same problem for some time now... with no avail...
maybe Plus should employ some real developers instead of virtual ones.
I dont think that the lack of ability to get the full sync speed for downloading is a wrong management.
Rather more the way I understand it is that the reason we all lack an email or ticket is because BT need to supply Plusnet with a delta report. So in essence plusnet didnt have a clue you had been upgraded till you told them. Even now they cant do nothing till BT have finished their tests.
But thats how I have understood it
Regards,
Level 2 now, and i'm yet to his 1.5GB peak Shockedops:
