Using CRON to automate Webalizer
Apologies if this is a duplicate, but my reply to my original thread hasn't updated on the portal.
> > I seem to have answered it for myself as I uploaded my local 'fstat.conf' into the 'stats' sub-directory. This wouldn't work as it was not pointing to the log file. I changed the first line to
> > 'LogFile stats.log' and it now works OK. I've now set up a crontab to automate it, so hopefully all is well.
> Please let me know if I can help you any further.
Yes, hopefully. I've been fiddling around with CRON for the last few days. The tech. support page gives these examples;
0 * * * * /home/files1/username/scriptname.php
10 * * * * /home/files1/username/cgi-bin/script2.cgi
23 10 10 * * /home/files1/username/script.php
so I tried '0 2 * * * /home/files3/rcdalton/stats/autostat'
then I noticed that this was different from the path in the Web Stats tech. supp. so I tried '0 2 * * * /files/home3/rcdalton/stats/autostat'
Still no joy. 'autostat' runs fine from Telnet, but not using CRON. Can you see where I'm going wrong?
Paul Brooks
RE: Using CRON to automate Webalizer
Hi Paul,
I have never used CRON before, so I am unable to help you on this one. The chap who takes over from me this afternoon, does. I am sure he will answer your questions.
If I can help you with anything else, please let me know.
Regards,
Dave
| David Scarpa...................Unmetered & ADSL solutions
| Senior Technical Consultant...........for Home & Business
| PlusNet Technologies Ltd............@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
kjaerligkatt
It sounds like you've fallen into the same trap as I did. You need to use the FULL path to webalizer in your script that is being executed by the cron job.
You can find the full path from a telnet session:
locate webalizer
From memory its /usr/local/bin
Neil
> Paul Brooks
> locate webalizer
Yes it is, thanks. I'm still having no luck though. Do I need the full path in every part of my 'autostat' script and in the various files in 'stats.conf'?
Paul Brooks
kjaerligkatt
> Paul Brooks
It depends on what you're doing Smiley
My script is not written how I would like to, since 'snarf' won't work for my account, and Plusnet can't find out why. Therefore, I have to change the directory to my stats working directory before using 'wget', which doesn't allow a destination filename to be specified. This removes the need for a full pathname for the ftp.
Using full pathnames, however, isn't a bad idea.
Try redirecting the webalizer output to a text file to see what's going on in the script:
/usr/local/bin/webalizer ~c ~/stats.stats.conf > ~/log.txt
will put a file, log.txt, in your home directory. Open this to see if webalizer is generating any errors in your script.
Neil Gardner
