Usenet speeds (so slooowww)
flyer99
Hi All
Is anyone else having problems with downloading from public usenet servers? I am currenlty seeing anything between 70kb and 150kb, usually I get 300kb upwards. Also the last 2 downloads every single file has ended up corrupted. I am using astraweb and have until today never had an issue. They report no issues at their end?
Regards
Nick
Plusnet Staff
Plusnet Staff
Hi Nick,
I saw another thread about this yesterday here, although with the corruption I'm wondering if this is a seperate issue.
Are you downloading files that come with par2 files? If so are articles missing parts? That would more likely indicate a problem with those post or with the news server.
If the files are being corrupted by the client instead it might be worth trying a different client (Grabit's free and worth a try).
The only corrupted files I received from Astraweb had missing parts according to Quickpar, which it quickly recovered for me.
Astraweb's speed does seem to vary a lot though regardless of ISP. Sometimes I get 30kB/sec and others I get 600kB/sec. Don't forget it might not be Astraweb thats slow, or Plusnet, but someone in between.
flyer99
Hi
This morning speed is back to what I would expect and at a constant rate not up and down like a yoyo. Regards Pars yes I have them but they are not much use when every file has blocks missing and so do the Par files themselves.(reported by quickpar)
I shall try another set of files to see what happens. My client newsleecher has always worked 100% but i do have xnews to fall back on for testing purposes. I will go take a look at grabits though
Nick
